Thames Sailing Barge Veronica
Seguidores (4)
Jerry
Does this model of Veronica have working leeboards or a removable false keel that could be adjusted fore and aft ? On my 12" : foot model the leeboards hinge/pivot on a round bar and I have to slide the hinge assembly forward to get her to balance when I set the jib as well as the stays'l. Lazy skippers leave it forward and trim by heaving the leeboards up a bit, causing less helm but DREADFUL leeway.
Best wishes and a beam reach!
Lemmerhengst
Cheers, Nerys
Cheers, Nerys
Really interesting build.
Not something I know a great deal about, but Certainly Nerys has a wealth of knowledge on your project.
Martin has given some good info on the servos.
Never be afraid to ask.
Regards Bill
Cheers, Nerys.
We are really enjoying the process 😀
Jerry
Are you building Veronica from the Sarik part kit and plans, scratchbuilt with the plans, or from a GRP hull? She is a very popular boat to build and performs well. I remember the real Veronica in her racing days. I have built several Thames barges of various types, but I'm getting on a bit and prefer the 1/32 size, about 30", I find that size easier to handle out of the water.You will get a lot of help on here if you ever need it, and you probably will, and most of us do from time to time, but there is a facebook page that relates purely to model barges, it's the Association of Model Barge Owners. I hope I'm not being disloyal in telling you that. Only too pleased to help if I possibly can.
Cheers, Nerys
Cheers, Nerys
Don't forget to post the log in the Build Log section.I am looking forward to seeing it.
If you find you need help then just shout i am sure the members here will help you.
Good luck with the build.
The information Martin has directed you to is going to point you in the right direction.
I tend to be somewhat haphazard in these matters, I haven't built a Veronica but have built a model barge to the same scale, probably carrying a little more sail than Veronica. I just used a couple of servos I happened to have at the time, a reasonably powerful one for the steering and a bit bigger one for the sails. No problems at all with either steering or sail handling. However if I was building a barge that size again, I would use a winch type servo for the sails.
Cheers, Nerys
Welcome to the site.
This might help you in your decision as to choice of servos.
https://www.eurorc.com/page/139/how-to-choose-a-servo
Will you be doing a build log on your Veronica ?
Jerry
Gostado por
A carregar…
