Hi Neil,
The guys here are a great bunch as you know.
We all enjoy making our models and talking about them so if you can manage both it will be really great.
We are here to help if we can so just shout.
Hi Neil,
Hi Neil,
I like your attitude, 'I'd rather be posting on here', please do, we need all the posts we can get, to provoke as much discussion as possible. Building boats is just as, if not more, important, but it's discussion we urgently need to wake this sleeping giant up again and make it the super interesting place it once was.
Cheers, Nerys
Hi Neil,
Cheers, Nerys
Hi Stephen
Not embarrassing at all.......I think I have a couple floating around as it's been so long in getting to this point 😆🤣🤣
I think I'd rather be posting on here than building which is my problem 😆
Hopefully get some new posts and move this on some more
Cheers Neil
Cheers Neil
Hi Neil, as the onwards and upwards didn't help you let's try something else instead. Ten dollar question what are you building? Is this a kit, scratch-built, or whatever, what is the hull made from, plastic, fiberglass, or timber? Is the hull complete with fittings, as in wash-ports, hawser holes, prop-shaft, rudder, etc? I think a few photos would definitely help to clarify your present predicament and be very helpful for us outsiders offering advice. What will be your power source, (I would love you to say STEAM,) but that is probably unlikely as I do appreciate it is a little expensive. So basically the situation is a little more information please, and I shall consult the oracle on your behalf. Regards Gary.
Hi Stephen
I have a very embarrassongly old build blog that I started 6 years ago 🤣 its almost a all the tools and bits but no knowledge blog 🤣
It's titled - Crash Tender Restoration after Plywood Delimitation
I will keep it updated though once I get started again
Cheers Neil
Hi Stephen
Cheers Neil
Onwards and upwards is a great motto I just need to master the Onwards bit as opposed to the upwards struggle of knowing what to do.....or over thinking 🤣🤣🤣
Good to see you're in agreement with Rick and to go for the hull first then the rest later. A real good point on spraying and hopefully the weather holds for the next month or so.....but it is the UK 🤔
I'm going with both of you and hopefully get something done this weekend.
Cheers Neil
Cheers Neil
Hi Neil, and not sure which way to go, that is easy and there is only one answer to that question. Onwards and Upwards my friend, onwards and upwards in some sort of logical order. I would also take into account the weather is changing and getting colder, if you are paint spraying outside then do it sooner rather than later. The order you build is entirely up to you and very much your choice, though normally I would say sort the hull first, followed by whatever goes inside it, then maybe the deck followed by the superstructure and fittings. It really doesn't matter about the order it goes together, as long as it ends up as a boat in one piece. Onwards and Upwards Neil, don't forget. Regards, Gary.
Hi Rick
Thanks for the reply and guidance which I'll be taking onboard, as mulling over its the most sensible route.
Finishing off the hull also gives me some more time to figure out the best layout for electrics based on all the blogs.....no point in reinventing the wheel 😊
Thanks again much appreciated
Neil
Hi Rick
Neil
Hi Neil I would prime the hull and fix any imperfections.
Fit the electronics into the boat make sure every thing is set up .
Start and build the superstructure making sure of the fit.
You will be handling the boat fitting all items in and touch up may be needed before final painting.
We all do the builds differently but end up with a finished boat. WE HOPE.
Rick
Rick
Hi,
Hope you are all safe and well?
So after a crazy year or so with no time to do anything constructive things are getting a little quieter. So I thought I'd start back on my extended project......but I'm lost where to start.
I have a the hull rubbed down but no superstructure fitted. Do I prime the hull and get ready for final paint then do the superstructure etc? Or do I fit the electrics, steering gear and all the superstructure and then paint everything?
I've looked at some of the blogs and just can't figure the right way to go so any help would be much appreciated......even if it is a matter of choice your expert guidance is always a help.
Cheers Neil
Cheers Neil
Apoio Model Boats Website com uma participação e desbloqueie sem anúncios, descarregamentos de imagens, passados puzzles e mais — a partir de apenas alguns pounds por mês.
